Hi All,
I've just had an Avant 55 installed, very happy with it.
Does anyone know which button to use on the remote to record on sky though? it's the only thing I can't figure out.
Paul
I have sky on my beo4 press menu then 8 an r will then be against the programme you are going to record
cheers
malcolm
Hi Paul
I'm just having the same problem with my Beoremote 1 and Sky+HD on my BV14-55. Did you ever get an answer from anyone. Thanks
There should be an overlay menu (from the PUC), when you press Menu - this should show you which button/button combination to use.
Hi Everyone. thanks for your answers but I've just worked it out. With the future program you want to record highlighted in the sky guide, press the list button on the Beoremote 1, highlight Sky HD as the source, there is a "right arrow" next to it. Press the right arrow on the main selector and then scroll down to the "record" label. Select that and the usual "record once, record series" window appears. Use the up & down arrows to select then go.
Best Wishes
