Beomaster 3300 repair (UK)
This post has 9 Replies | 0 Followers
Voe1
Posts 6
Voe1 Posted: Fri, Aug 12 2016 10:00 AM
Hello, my Beomaster CD door is not opening unless I force it. This was the drive belt last time. The Stafford company I used to fix it is not dealing with the 3300 any more as it is too old! (Lack of spares). Please can you tell me whether you know someone in the UK who fixes Beomaster 3300s? I love the old machine and am not worried if non genuine parts are used to fix it. I just want it to work!
Thanks a lot.
Voe1
Posts 6
Voe1 replied on Mon, Oct 3 2016 1:32 PM
Would still appreciate advice on this. Any thought anyone please?
solderon29
U.K.West Midlands
Posts 764
Do you mean Beogram CD3300(cd player) praps?
Voe1
Posts 6
Voe1 replied on Thu, Jan 19 2017 10:33 AM
Hello Solderon, yes I do.
Apologies for slow reply. Would you be able to assist at all please?
solderon29
U.K.West Midlands
Posts 764
Under the front edge of the lid,you will see two black blobs.These are to cushion the door when it closes,but they go soft and stick to the door preventing it from opening.Just remove them and see if the door opens normally?
Otherwise,the door belt may have stretched again,or if the door was sticking the gear teeth may have stripped!!!
Regards,
Nick
Voe1
Posts 6
Voe1 replied on Fri, Jan 20 2017 3:03 PM
Thanks a lot for your reply Nick. I've checked the black blobs and they're okay, so I suspect your 'teeth missing' theory. I can ease the door open but when it comes to closing, it clatters down. Feels a bit terminal if it is teeth. Maybe I'll be able to use the unit for another couple of years by manually easing door open and closed. Hate the lack of mechanical sympathy though.. Probably not worth much now either. Argh! Frustrating. Thanks again for your input.
solderon29
U.K.West Midlands
Posts 764
is there a motor noise when you press the lid/eject button?
If there is,it means the lid drive is running and the connecting gear is stripped.If there is no motor noise,it suggests that the sensor for lid eject etc is faulty.
Good machines these,well worth repair.Do you want to send/bring it to me for investigation?
Regards,
Nick
Voe1
Posts 6
Voe1 replied on Tue, Jan 24 2017 10:17 AM
Hello Nick,
No there is no motor noise on opening. On closing there is motor noise once I gently 'persuade' lid to close but also that clattering sound. I imagine I have both issues?
You've made a fantastic offer. Thank-you. The machine has sentimental value to me as it was handed down to me. I'd love to get it investigated and maybe, if I'm very lucky, fixed. I'll PM you to see what you think. Thanks! Regards, M
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jan 24 2017 12:25 PM
Perhaps a broken or bent contact in the lid mech.
Voe1
Posts 6
Voe1 replied on Sat, Jan 28 2017 11:53 AM
Okay, thank-you Dillon. Hopefully not too expensive!!
Page 1 of 1 (10 items) | RSS
