Avant 75 + Beolab Penta?
This post has 16 Replies | 1 Follower
Kiran
UK
Posts 1,023
Kiran Posted: Sun, Mar 19 2017 10:59 AM
Hi All
I tried to connect my Beolab Penta with my new Avant but no luck? Maybe I did something wrong?
Powerlink from Avant (RJ45 to 8pin) into ML/MCL converter. Converter has 2 old pin outputs for the speakers.
It didn't work.
Any ideas?
Regards
Kiran
Born in NL; I ride ML
Millemissen
Flensborg, Denmark
Posts 14,680
You'll need the 'fully wired' PL cable.
(Otherwise the converter won't turn on/trigger on).
Ask your B&O dealer or Steve at SoundsHeavenly for help (and details).
Kiran
UK
Posts 1,023
Kiran replied on Sun, Mar 19 2017 11:26 AM
Millemissen:
My RJ45 to Powerlink cable was from Steve.
Maybe not the right spec? There's only one of them on the site with different lengths.
Regards
Kiran
Millemissen
Flensborg, Denmark
Posts 14,680
This - from Steve - should be the right one - (is that the one you have?).
http://soundsheavenly.com/bang-olufsen/31-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html
From B&O it should be these:
'The cables 6271225 and 6271226 are needed with the ML/MCL Converter and BeoLink Passive only.'
Hungedu
United States
Posts 165
Hungedu replied on Sun, Mar 19 2017 2:54 PM
Please post some photos of the Pentas next to your Avant once you have everything set. Up. I was thinking of mating my Pentas with an Avant 55. I'd love to see how this looks.Smile
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Kiran
UK
Posts 1,023
Kiran replied on Tue, Mar 21 2017 9:09 AM
I have put them away in storage while the house is being done.
I wish I knew about what MM said earlier.
I was going to keep them in the living room for a while until the house gets complete.
Regards
Kiran
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Mar 21 2017 10:08 AM
Hungedu - from me to you.
Yes - thumbs up
Shaun.
Posts 19
Shaun. replied on Tue, Mar 21 2017 11:30 AM
Iv'e got the penta's with my Avant 55'.
The display's work to.πŸŒΉπŸ€—
Sorry for the mess with the sockets on the Wall etc.
But right now i live in a rented house...πŸ€‘πŸ˜‰
Shaun.
Hungedu
United States
Posts 165
Hungedu replied on Wed, Mar 22 2017 12:44 AM
Thanks for posting the picture!
Hungedu
United States
Posts 165
Hungedu replied on Wed, Mar 22 2017 12:45 AM
Nice to see these side by side! Thanks!
Sweden
Posts 357
Silver Member
Martin replied on Thu, Mar 23 2017 6:00 AM
Hi shaun, are your Pentas connected directly to the avant or to your beosystem 7000?
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Shaun.
Posts 19
Shaun. replied on Thu, Mar 23 2017 9:02 AM
Martin:
best regards
Hi Martin.
They are connected directly to the Avant.πŸ€—
And i use a ML/MCL amp to drive 2 beovox 3000 as rear surround speakers.😊
Kiran
UK
Posts 1,023
Kiran replied on Thu, Mar 23 2017 9:09 AM
I tried to do that.
I too have the ML/MCL converter.
Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable?
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, Mar 23 2017 9:12 AM
Here is some pics:
Regards
Kiran
Shaun.
Posts 19
Shaun. replied on Thu, Mar 23 2017 9:45 AM
Kiran:
I tried to do that.
Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable? Regards
Kiran
Hi Kiran.
My Amp looks just like yours at the back.
I remember that the the b&o guy cut some wires, but can't remember where...β˜ΊοΈπŸ‘ŒπŸ»
Peter Pan
Posts 2,088
Peter Pan replied on Thu, Mar 23 2017 10:47 AM
Connection for Old school B&O to BeoLab Penta Mk. I
______________________
CasperI
Posts 93
CasperI replied on Thu, Mar 23 2017 4:30 PM
If you want the Avant to switch on the ML/MCL converter, you need to switch 2 wires in one of the connectors. The yellow and the grey (Pin1 & 4).
That should work Thumbs Up
Page 1 of 1 (17 items) | RSS
