Regards
Kiran
Born in NL; I ride ML
You'll need the 'fully wired' PL cable.
(Otherwise the converter won't turn on/trigger on).
Ask your B&O dealer or Steve at SoundsHeavenly for help (and details).
Millemissen:You'll need the 'fully wired' PL cable. (Otherwise the converter won't turn on/trigger on). Ask your B&O dealer or Steve at SoundsHeavenly for help (and details). MM There is a tv - and there is a BV.
This - from Steve - should be the right one - (is that the one you have?).
http://soundsheavenly.com/bang-olufsen/31-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html
From B&O it should be these:
'The cables 6271225 and 6271226 are needed with the ML/MCL Converter and BeoLink Passive only.'
Please post some photos of the Pentas next to your Avant once you have everything set. Up. I was thinking of mating my Pentas with an Avant 55. I'd love to see how this looks.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Hungedu - from me to you.
Hi shaun, are your Pentas connected directly to the avant or to your beosystem 7000?
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Martin:Hi shaun, are your Pentas connected directly to the avant or to your beosystem 7000? best regards Martin
Kiran:I tried to do that. I too have the ML/MCL converter. Can you confirm the pins for the Penta cable on the converter has a 3 pint input. Did you have to cut 1 of the 4 pins on the cable? Regards Kiran Born in NL; I ride ML
Connection for Old school B&O to BeoLab Penta Mk. I
______________________
If you want the Avant to switch on the ML/MCL converter, you need to switch 2 wires in one of the connectors. The yellow and the grey (Pin1 & 4).
That should work
