Dead beolab 2?
This post has 6 Replies | 0 Followers
andrew
Sussex UK
Posts 47
andrew Posted: Sat, Mar 4 2017 10:42 AM
Hi. I've just bought a beolab 2 from eBay, to use with my beolab 8000's. I have plugged it into the mains, linked the beolab 8000's into the back of the beolab 2, and the beolab 2 is linked into the back of the beomaster 7000.
The beolab 8000's are playing fine but I cannot hear ANYTHING from the beolab 2 ... It is making no sound at all. Have I set it up wrongly? Or is it dead?
I have put the input lead for the beolab 2 into one of the output sockets in the beomaster - is this not right?
Thanks,
Andrew
davidr
Montréal
Posts 172
davidr replied on Sat, Mar 4 2017 2:10 PM
Andrew, that reads exactly like my issue with taking shipment of a Beolab 2. First few questions, does the LED change from red to green? Your connection also seems correct, one PL from BM7000 to Beolab 2 input, two BL2 outputs going to 8000s correct?
My BL2 had exactly this behaviour from probably some trauma from shipping. Connected everything, LED would change from red to green, no bass from the BL2 but the 8000s playing just fine. Triggering was working just no bass sound. Tried every combination of the BL2 switches, tried unplugging the 8000s - same result.
If that's so then I'm afraid your BL2 amp board (there's only one) will need replacement. At least in Canada these boards are still available and mine was replaced about 6 months ago.
andrew
Sussex UK
Posts 47
andrew replied on Sat, Mar 4 2017 2:24 PM
Thanks for the reply. Yes, the LED changes colour ...  I shall have to find a repairer in that case. Sad news ...
Beobuddy
Utrecht, The Netherlands
Posts 3,972
I once got his. A broken magnet inside.
Ordering a new woofer wasn't in it's budget, so fixed this one. But nevertheless, in this state they don't do much..
Beobuddy
Posts 3,972
Forgot to mention, broke after shipment in wrong package.
marexy
Posts 710
marexy replied on Tue, Mar 7 2017 1:31 PM
ugly injury ... very sloppy sender
Spaxy
Posts 1
Spaxy replied on Wed, May 10 2017 12:05 AM
So has it been fixed?
What would they charge for a new speaker?
Look pretty bad to be honest. The problem might also be that the magnet is simply to heavy: when the speaker makes a drop means that the heavy gains to much energy so that it will crack off the rest of the speaker. In other words: the weight is not considered while designing the speaker when falling. It might be a "design flaw"sort off ....
Page 1 of 1 (7 items) | RSS
