Beocenter 2300 Fm radio not locking on channels
This post has 5 Replies | 0 Followers
Struer
London
Posts 106
Struer Posted: Sat, May 27 2017 8:12 AM
Dear Beoworld, a few queries here. My Beocenter 2300 Fm radio is tuning not locking on any channels, even
wiyu a new antennae ribbon. Also the glass doors don't close tight, they are a fraction out. Any ideas?
kkind regards
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sat, May 27 2017 11:20 AM
Struer:
kkind regards
The FM board is dead, nothing you can do about it unfortunately. It is a common problem, have n to heard of anyone getting one working again. I have had a lot of them die.
Only thing to do is find a donor board that works.
The glass doors can be adjusted and old dirt removed from the gliders, then they work again.
/Jacob
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, May 27 2017 12:20 PM
Are only the presets not locked? Does the searchfunction still work?
If the backup battery is dead, several basic settings are lost.
Struer
London
Posts 106
Hi Jacob,
thanks for getting back to me. Much appreciated.
Kieron
Struer
London
Posts 106
Hi Beobuddy,
When I scan it only stops on one FM channel. I can assign this one Channel to a preset.
Struer
London
Posts 106
Hi how might I re adjust the glass doors.
Is it possible to find a suitable defused glass replacement as one of the doors is chipped?
Is it normal to trigger the sensor and the doors open when walking near or past the front of the system. Is there usually a few seconds delay from when pressing play on a cd and the doors closing?
Also there's a slight static charge emulating from the stainless steel face
below the CD player.
Apart fro that it seems to work fine...
Page 1 of 1 (6 items) | RSS
