Dear Beoworld, a few queries here. My Beocenter 2300 Fm radio is tuning not locking on any channels, even
wiyu a new antennae ribbon. Also the glass doors don't close tight, they are a fraction out. Any ideas?
kkind regards
Struer: Dear Beoworld, a few queries here. My Beocenter 2300 Fm radio is tuning not locking on any channels, even wiyu a new antennae ribbon. Also the glass doors don't close tight, they are a fraction out. Any ideas? kkind regards
The FM board is dead, nothing you can do about it unfortunately. It is a common problem, have n to heard of anyone getting one working again. I have had a lot of them die.
Only thing to do is find a donor board that works.
The glass doors can be adjusted and old dirt removed from the gliders, then they work again.
/Jacob
Are only the presets not locked? Does the searchfunction still work?
If the backup battery is dead, several basic settings are lost.
Hi Jacob,
thanks for getting back to me. Much appreciated.
Kieron
