Hi:
I am a new member here, and looking forward to helping and being help by other members.
I have a ouverture 2631, when removing the doors to repair the door belt, I managed to break off 2 of the metal brackets from the doors.
Looking fer recomendation on suitable adhesive to repair the doors.
Many thanks.
Araldite 2-part epoxy. Do a keyword search for it here in the forums and you'll see how often it's mentioned.
Thank you to MediaBobNY for your help.
Mac
Hello,
Did you tried it for yourself or is it just a guess?
No offense but it seems to be easier ro use than any two component glue, but i would to be sure of the efficiency.
Thank you.
Thank you Leogoeswild.
