Adhesive for doors
mm01
Posts 2
mm01 Posted: Sat, Jul 22 2017 12:26 AM
Hi:
I am a new member here, and looking forward to helping and being help by other members.
I have a ouverture 2631, when removing the doors to repair the door belt, I managed to break off 2 of the metal brackets from the doors.
Looking fer recomendation on suitable adhesive to repair the doors.
Many thanks.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Araldite 2-part epoxy.  Do a keyword search for it here in the forums and you'll see how often it's mentioned.
mm01
Posts 2
mm01 replied on Fri, Jul 28 2017 10:06 AM
Thank you to MediaBobNY for your help.
Mac
leosgonewild
Helsinki, Finland
Posts 2,373
Gorilla glue Wink
matador43
Posts 1,373
matador43 replied on Fri, Jul 28 2017 2:02 PM
Hello,
Did you tried it for yourself or is it just a guess?
No offense but it seems to be easier ro use than any two component glue, but i would to be sure of the efficiency.
Thank you.
leosgonewild
Helsinki, Finland
Posts 2,373
I have used epoxy before. May or not fall off. I haven tried the gorilla glue, but I have tried the gorilla tape. It is like duct tape, just about 20times stronger.
leosgonewild
Helsinki, Finland
Posts 2,373
https://youtu.be/dgpR-SaWgZs
matador43
Posts 1,373
matador43 replied on Fri, Jul 28 2017 2:35 PM
Thank you Leogoeswild.
Page 1 of 1 (8 items) | RSS
