Lutron grafix eye
kai
Posts 362
kai Posted: Fri, Sep 15 2017 10:32 PM
Question beo5 has been damaged and now have a beo4, all working ok but the grafix eye which is the one that works with the bang and olufsen remote control, has worked for many years still works hands on but not the bang and olufsen remote, has any one experienced this?
expoman
Posts 182
Silver Member
expoman replied on Sun, Sep 17 2017 6:16 AM
Do you have the Old BEO 4 or the new version with the joy stick instead of the go button?  There could be different IR codes.  I have six graphic eyes that all still work with Original BEO 4. Have not tried the new Beo 4 or the BEO remote 1.
kai
Posts 362
kai replied on Sun, Sep 17 2017 9:38 PM
Hi thanks for the reply it is the one with joystick, old remote and newer remote use the same ir, bvis 4 still works cd, radio etc, just lights are not working with the remote
Page 1 of 1 (3 items) | RSS
