Silent gliss electric track
This post has 5 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Fri, Sep 15 2017 6:59 PM
Hello beofans
I have a silent gliss 5090 electric curtain track.
It has IR & push button.
It has two bends and was a bespoke order for my square bay window.
I can give measurements if anyone wants to know as there might be a slim chance it could benefit someone
I am moving house and my buyers don't want it
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hello Seanie_230,
Yes, could you post the measurements please?  I'm guessing you currently use either the Silent Gliss remote or Masterlink Gateway to control this? (I don't recall seeing a curtain track that worked directly from a B&O remote?)
Thanks, Steve.
Steve.
www.soundsheavenly.com
Seanie_230
UK
Posts 2,278
Hello
I use the push button and silent gliss IR remote.
I actually have the push button wired to a global cache relay controlled by BLGW.
Will post the measurements of the bay this evening.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
197x64cm
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Inside the 197 is 1.5cm batten so it's actually 194cm
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Posts 2,165
Hi Sean,
Looks like my window is wider than I thought, unfortunately I will need a longer track.  Thanks anyway.
Kind regards, Steve.
Steve.
Page 1 of 1 (6 items) | RSS
