Eclipse 65V1-32Beosound M5Essence MK2BLI
Hello Seanie_230,
Yes, could you post the measurements please? I'm guessing you currently use either the Silent Gliss remote or Masterlink Gateway to control this? (I don't recall seeing a curtain track that worked directly from a B&O remote?)
Thanks, Steve.
Steve.
www.soundsheavenly.com
Hi Sean,
Looks like my window is wider than I thought, unfortunately I will need a longer track. Thanks anyway.
Kind regards, Steve.
