Beolab 11 wall mount what size bolts
badgersurf
Posts 539
badgersurf Posted: Sat, Sep 16 2017 9:34 AM
Hi all,
Any one know what size bolts are used to connect the BL11 to the wall bracket.
Toby
badgersurf
Posts 539
Hi All,
Does anyone have any idea what size bolts the beolab11 fixes onto the wall mount?
Toby
bigl666
Posts 1
bigl666 replied on Tue, Sep 19 2017 5:09 PM
here it is from the manual:
Use the correct size and type of screws and wall anchors – taking into account the construction and condition of the wall. Use 3 flat-bottom head screws (Ø 4.2 mm – 0.16”) and wall anchors each with a minimum load rating of 50 kg (110 lbs).
Special notice about light partition walls If you intend to hang the BeoLab on a gypsum wall (also known as drywall or wallboard), the wall bracket must be fastened to a vertical stud. Mounting was evaluated for use on a drywall surface. Use 1 screw (Ø 4.2 mm – 0.16”), which penetrates the gypsum and are screwed a minimum of 50 mm (2”) into a vertical stud. Furthermore, use 2 additional screws of a type intended for gypsum walls.
good luck -)
cu
Stefan
badgersurf
Posts 539
Thanks Stefan for your response. I have the bracket attached to the wall, it is the size of the screws that bolt the Beolab onto the base of the wall bracket I am after. there are 4 screws and all it says in the manual I can find is that they are called F! but there is no size.
Hope someone can help.
Toby
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Sep 20 2017 1:52 PM
badgersurf:
Toby
Those bolts are supplied with the bracket, if I remember correctly. Right?
I guess you have to take both bracket and BL11 down to the "bolt shop" and try ot what may fit.
Page 1 of 1 (5 items) | RSS
