Hi All,
Does anyone have any idea what size bolts the beolab11 fixes onto the wall mount?
Toby
here it is from the manual:
Use the correct size and type of screws and wall anchors – taking into account the construction and condition of the wall. Use 3 flat-bottom head screws (Ø 4.2 mm – 0.16”) and wall anchors each with a minimum load rating of 50 kg (110 lbs).
Special notice about light partition walls If you intend to hang the BeoLab on a gypsum wall (also known as drywall or wallboard), the wall bracket must be fastened to a vertical stud. Mounting was evaluated for use on a drywall surface. Use 1 screw (Ø 4.2 mm – 0.16”), which penetrates the gypsum and are screwed a minimum of 50 mm (2”) into a vertical stud. Furthermore, use 2 additional screws of a type intended for gypsum walls.
good luck -)
cu
Stefan
Thanks Stefan for your response. I have the bracket attached to the wall, it is the size of the screws that bolt the Beolab onto the base of the wall bracket I am after. there are 4 screws and all it says in the manual I can find is that they are called F! but there is no size.
Hope someone can help.
badgersurf: Thanks Stefan for your response. I have the bracket attached to the wall, it is the size of the screws that bolt the Beolab onto the base of the wall bracket I am after. there are 4 screws and all it says in the manual I can find is that they are called F! but there is no size. Hope someone can help. Thanks Toby
Those bolts are supplied with the bracket, if I remember correctly. Right?
I guess you have to take both bracket and BL11 down to the "bolt shop" and try ot what may fit.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
