- Flere
smile and enjoy the moment
Hi Flere,
You can use a wired digital connection to Beolab 50 from older Beosound music systems, eg. Beosound 9000 or Beomaster 5 via an S/PDIF cable:-
https://www.soundsheavenly.com/beolab-5-beolab-50-and-beolab-90/34--spdif-.html
Newer B&O music systems lack the digital output, which is a shame. However, you can still use an analogue connection from newer systems.
Kind regards, Steve.
Steve.
Steve at Sounds Heavenly:Hi Flere, You can use a wired digital connection to Beolab 50 from older Beosound music systems, eg. Beosound 9000 or Beomaster 5 via an S/PDIF cable:- https://www.soundsheavenly.com/beolab-5-beolab-50-and-beolab-90/34--spdif-.html Newer B&O music systems lack the digital output, which is a shame. However, you can still use an analogue connection from newer systems. Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor the BeoWorld forums!
Good point! I had forgotten about the optical output on the Core.
Nothing - as of now!
