Boplay A2 general update questions
This post has 1 Reply | 0 Followers
marexy
Posts 710
marexy Posted: Thu, Aug 23 2018 11:24 AM
Given the fact that the serial battery is very poor and old software, I would ask the following:
- Have any of you replaced for a non B&O original battery for at least 4000 mAh ?
- Does anyone have an experience with  firmware update ?
- Is it compatible with the Beolay application after upgrade ?
marexy
Posts 710
marexy replied on Fri, Aug 24 2018 6:33 AM
Hi
No one did retrofit of battery :(
Unit plays for 1 hour max at 80% volume.
Far far less then 24 hour as indicated at B&O specifications.
Page 1 of 1 (2 items) | RSS
