Given the fact that the serial battery is very poor and old software, I would ask the following:- Have any of you replaced for a non B&O original battery for at least 4000 mAh ?- Does anyone have an experience with firmware update ?- Is it compatible with the Beolay application after upgrade ?
Hi
No one did retrofit of battery :(
Unit plays for 1 hour max at 80% volume.
Far far less then 24 hour as indicated at B&O specifications.
