Beosound 5 encore, MLGateway, and ML NL Converter
eromano
Posts 3
eromano Posted: Sun, Oct 11 2020 7:50 PM
I have a beosound 5 encore which I would like to remotely control through the Beolink iPad app and a  Masterlink gateway.
The MLGW is working with the last software 2.24b, however it fails to recognize the Beosound on the network.
However, my understanding is that the beosound encore is a NetLink product (NL). Should I use a NL/ML converter to connect it to the Masterlink gateway ?
Thank you for your help.
Regards
Elliot
lawrencejmcook
Posts 742
eromano:
Regards
Elliot
Hi Elliot,
The BS5 Encore has neither Netlink nor Masterlink. Its Ethernet socket allows it to play music via DLNA from a server on your network, e.g. a Beomaster 5 or a NAS running a compatible DLNA server.
(The BS5/BM5 combo has Masterlink, so you could make that Netlink-compatible using a BLC NL/ML.)
As the MLGW is designed to integrate B&O and non-B&O, you may be able to make it issue IR commands from a B&O remote in another room. But I have no experience in this area.
If you ever succeed in making the BS5E Netlink-compatible using the MLGW, do let me know, as I have a BS5E and a BLGW.
Lawrence
Page 1 of 1 (2 items) | RSS
