I have a beosound 5 encore which I would like to remotely control through the Beolink iPad app and a Masterlink gateway.
The MLGW is working with the last software 2.24b, however it fails to recognize the Beosound on the network.
However, my understanding is that the beosound encore is a NetLink product (NL). Should I use a NL/ML converter to connect it to the Masterlink gateway ?
Thank you for your help.
Regards
Elliot
eromano:Hi, I have a beosound 5 encore which I would like to remotely control through the Beolink iPad app and a Masterlink gateway. The MLGW is working with the last software 2.24b, however it fails to recognize the Beosound on the network. However, my understanding is that the beosound encore is a NetLink product (NL). Should I use a NL/ML converter to connect it to the Masterlink gateway ?Thank you for your help.RegardsElliot
