Jordans S40's
This post has 14 Replies | 1 Follower
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Sun, May 6 2018 10:13 AM
Jordan turned up yesterday with these.....could I refoam them for him.
Craig
Posts 2,040
Silver Member
Never having performed this procedure I have looked back over previous threads for guidance, removing the grills reveals the extent of the decay.
Craig
Posts 2,040
Silver Member
It being such a nice morning I decided to do this alfresco........
Craig
Posts 2,040
Silver Member
First one has cleaned up really well, the old foam fell away almost by itself.........
Craig
Posts 2,040
Silver Member
New rubber offered up for size and looks a good fit, I will need to remove the dust cap to fit shims, the cone is all over the place and the chances of lining everything up without shims seems remote
Craig
Posts 2,040
Silver Member
Craig replied on Sun, May 6 2018 10:25 AM
I think the rubber should be glued to the cone first, once set the cone will be glued to the frame........unless anyone thinks otherwise?
Craig
Saint Beogrowler
Saint Paul
Posts 780
Craig:
Craig
That is how I do it too
Beofile7
Posts 150
Reading "Jordans s40's" I opened this discussion expecting to see quite different photos!!!
Craig
Posts 2,040
Silver Member
Not since the court case I'm afraid ;~)
However dust cap removed from the first one and all shimmed up......
Craig
Posts 2,040
Silver Member
New rubber glued onto the cone.....left to set, bottle opened barbecue to sort next!
Craig
Posts 2,040
Silver Member
Rubber glued onto frame, shimms removed, dust cap back on  and speaker tests out fine....one down.
Craig
Posts 2,040
Silver Member
Second one complete, cone moving freely....will box it up tomorrow and test it out, I'm sure it will be fine.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Thu, May 10 2018 2:18 AM
I repaired some S40’s a few years back that had foam rot (thread on archived forum). My first “major” project really. I have modded them quite a bit since then. They are a fantastic little speaker. Great sound, and they can play quite loudly for their size. Lots of placement possibilities with no loss in fidelity. They even sounded great hanging in my garage as part of a 2400 system (replaced by P45s eventually).
Jord
Gateshead
Posts 3
Jord replied on Fri, May 11 2018 6:17 PM
Speakers connected back up last night, sounding great - after months of either being told "No, we don't do that" or "Well, we could look at them for £100 but can't guarantee anything" (that was B&O) I'm properly over the moon to have them back. Thanks Craig, you're a diamond!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, May 12 2018 12:34 AM
Fine work Craig! I always love seeing old, classic B&O gear lovingly brought back to life.
Jeff
Page 1 of 1 (15 items) | RSS
