Jordan turned up yesterday with these.....could I refoam them for him.
Never having performed this procedure I have looked back over previous threads for guidance, removing the grills reveals the extent of the decay.
It being such a nice morning I decided to do this alfresco........
First one has cleaned up really well, the old foam fell away almost by itself.........
New rubber offered up for size and looks a good fit, I will need to remove the dust cap to fit shims, the cone is all over the place and the chances of lining everything up without shims seems remote
I think the rubber should be glued to the cone first, once set the cone will be glued to the frame........unless anyone thinks otherwise?
Craig
Craig:I think the rubber should be glued to the cone first, once set the cone will be glued to the frame........unless anyone thinks otherwise? Craig
Reading "Jordans s40's" I opened this discussion expecting to see quite different photos!!!
Not since the court case I'm afraid ;~)
However dust cap removed from the first one and all shimmed up......
New rubber glued onto the cone.....left to set, bottle opened barbecue to sort next!
Rubber glued onto frame, shimms removed, dust cap back on and speaker tests out fine....one down.
Second one complete, cone moving freely....will box it up tomorrow and test it out, I'm sure it will be fine.
Speakers connected back up last night, sounding great - after months of either being told "No, we don't do that" or "Well, we could look at them for £100 but can't guarantee anything" (that was B&O) I'm properly over the moon to have them back. Thanks Craig, you're a diamond!
Fine work Craig! I always love seeing old, classic B&O gear lovingly brought back to life.
Jeff
