Dear Forum.
I have tried updating the firmware of my Beoplay A1 using a PC, using a Mac, using my Android phone, using my Ipad, with cable and also via bluetooth.
It´s just not working, how ever I try to du it the A1 shuts off after having downloaded about 40%, and the app/program says it has lost connection. I have now tried it about 40 times.
I have heard that a lot of people have had difficulties updating firmware with beoplay speakers, any suggestions? I have no other problem connecting to the app for example.
The reason I want to update the firmware is that I´m buying another A1 one for stereo-pairing and want them to have the same firmware.
Thanks in advance!
It worked fine for me on a Mac using the "BeoPlay Software Update" OSX application with A1 connected to the USB port.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Dear Yendy, thanks for your suggestion. I will try both PC and Mac with supplied and other USB c cables. I have a macbook air with latest os, My PC is also on win10 and I tried both the USB2.0 and 3.0 ports. The A1 shuts off when it has downloaded about 40%. It seems that the cable is working since it starts the data transfer but then the A1 shuts off after a whil.
Have tried to have the A1 plugged in and on battery, same result.
Today I bought an A2, I will try to update the A2 also, just give me some time :) And then compare.
Thanks everyone for suggestions!!! Keep em coming
Dear forum!
Now I have an updated Beoplay A1! I used the cable from when I bought the A2 Active, and updated from a mac with this USB-c cable, superfast and no problems.
I looked closely on both cables (the one that is supplied with the A1 and the one supplied with the A2 active ) and I can´t see any difference comparing these two cables, they look exactly the same, but only the A2 active USB-c cable seems to work.
I put the A1 in "update mode" (pushed the A1 power button when the app asked me to) and from there it took only a minute.
Anyway, many thanks for all your help that resolved my update problem :)
You might have just gotten a bum cable with your A1. I've updated my A1 with the supplied cable no problem.
It seems that both me and forum user "Yendy" had faulty or "no data" charging cables with our A1. I figured it was worth mentioning even if it is not the case for everyone.
