Beoplay A1 shuts off during firmware update, loses connection
rubatone
Posts 6
rubatone Posted: Sat, Mar 10 2018 6:26 PM
Dear Forum.
I have tried updating the firmware of my Beoplay A1 using a PC, using a Mac, using my Android phone, using my Ipad, with cable and also via bluetooth.
It´s just not working, how ever I try to du it the A1 shuts off after having downloaded about 40%, and the app/program says it has lost connection. I have now tried it about 40 times.
I have heard that a lot of people have had difficulties updating firmware with beoplay speakers, any suggestions? I have no other problem connecting to the app for example.
The reason I want to update the firmware is that I´m buying another A1 one for stereo-pairing and want them to have the same firmware.
Thanks in advance!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Mar 12 2018 3:15 PM
It worked fine for me on a Mac using the "BeoPlay Software Update" OSX application with A1 connected to the USB port.
Yendys
Sydney
Posts 312
Yendys replied on Tue, Mar 13 2018 7:43 AM
It didn’t work for me with beoplay app. But connected via USB to windows 10 pc and update app work perfectly
Yendys
Sydney
Posts 312
Yendys replied on Tue, Mar 13 2018 8:03 AM
Also you can’t update it with the cable shipped with the A1 it’s only a charge cable. You have to use/buy a sync/data cable. Go figure premium product cheap cable. Wasn’t happy when I had to go and buy one...
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard replied on Tue, Mar 13 2018 11:17 AM
I have been able to update my A1 using my Macbook Air, the B&O update app for Mac, and the cable that came with the A1.
Unless the supplied cable was broken, I don’t think it’s necessary to buy a new one.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
rubatone
Posts 6
rubatone replied on Tue, Mar 13 2018 11:30 AM
Dear Yendy, thanks for your suggestion. I will try both PC and Mac with supplied and other USB c cables. I have a macbook air with latest os, My PC is also on win10 and I tried both the USB2.0 and 3.0 ports. The A1 shuts off when it has downloaded about 40%. It seems that the cable is working since it starts the data transfer but then the A1 shuts off after a whil.
Have tried to have the A1 plugged in and on battery, same result.
Today I bought an A2, I will try to update the A2 also, just give me some time :) And then compare.
Thanks everyone for suggestions!!! Keep em coming
rubatone
Posts 6
rubatone replied on Fri, Mar 16 2018 4:51 PM
Dear forum!
Now I have an updated Beoplay A1! I used the cable from when I bought the A2 Active, and updated from a mac with this USB-c cable, superfast and no problems.
I looked closely on both cables (the one that is supplied with the A1 and the one supplied with the A2 active ) and I can´t see any difference comparing these two cables, they look exactly the same, but only the A2 active USB-c cable seems to work.
I put the A1 in "update mode" (pushed the A1 power button when the app asked me to) and from there it took only a minute.
Anyway, many thanks for all your help that resolved my update problem :)
Earle
Posts 223
Earle replied on Fri, Mar 16 2018 4:56 PM
You might have just gotten a bum cable with your A1. I've updated my A1 with the supplied cable no problem.
rubatone
Posts 6
rubatone replied on Sat, Mar 17 2018 6:59 AM
It seems that both me and forum user "Yendy" had faulty or "no data" charging cables with our A1. I figured it was worth mentioning even if it is not the case for everyone.
Page 1 of 1 (9 items) | RSS
