Beosound supporting speaker display
This post has 3 Replies | 4 Followers
Erik-nl
Posts 41
Erik-nl Posted: Thu, Feb 17 2022 6:05 PM
Can someone help which of the following Beosound system supports speaker display like in e.g. Pentas:
Beosound 4 ?
Beosound 5 ?
Beosound Moment ?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Erik-nl,
Beosound 4 supports speaker displays when used with fully wired Powerlink mk.2 cables but systems with the newer RJ45 Powerlink outputs like the Moment don't support this.  I apologise that I can't recall the exact situation for Beosound 5 Encore and Beomaster 5 but I don't think these support the speaker displays.  Hopefully someone here can confirm, as it is a long time since I tried either of these systems with Penta speakers!
I am always happy to help with any cables you need via my sponsor link below.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Feb 18 2022 4:55 PM
Beosound 5 should work..
The BM5 is mostly connected through masterlink and diagrams shows "PL-Data". It's from an era that powerlink data was common used.
PhilLondon
London
Posts 3,637
The BeoLink active supports speaker displays. So if you access most tv or Beosound through it, you’ll get the source name and track.
Beoworld app with direct photo upload and emoticons.
Page 1 of 1 (4 items) | RSS
