Beocenter 3500 but which speakers
This post has 1 Reply | 2 Followers
kingsley66
Posts 1
kingsley66 Posted: Fri, Apr 20 2018 10:41 PM
I have just bought a Beocenter 3500 however I wondered if I can use S35 or S40 passive speakers with it?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Kingsley66,
Welcome to Beoworld!
The simple answer is that you can use ANY speakers (either B&O or other brands, passive or active) with any classic Beocenter music system by adding the correct cables or adapters.
The S35 and S40 speakers are ideal, you just need 2 pin DIN cables like these to connect them to the Beocenter:-
https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/2-pin-din-beovox-cx-speaker-cables-pair-also-for-beovox-2500-and-rondstraler
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
