I have just bought a Beocenter 3500 however I wondered if I can use S35 or S40 passive speakers with it?
Hi Kingsley66,
Welcome to Beoworld!
The simple answer is that you can use ANY speakers (either B&O or other brands, passive or active) with any classic Beocenter music system by adding the correct cables or adapters.
The S35 and S40 speakers are ideal, you just need 2 pin DIN cables like these to connect them to the Beocenter:-
https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/2-pin-din-beovox-cx-speaker-cables-pair-also-for-beovox-2500-and-rondstraler
Kind regards, Steve.
Steve.
www.soundsheavenly.com
