Options setting!
frog
Camberley UK
Posts 624
frog Posted: Thu, Apr 5 2018 8:15 PM
hi,
im struggling with setting the options for my system - the main room comprises of:
Beosystem 3 (Option setting 2)
Beocentre 2 (Option 0)
Beosystem 5/Beomaster 5 (no audiomaster)
the speakers are connected to the Beosystem 3.
what I’m finding is that I can control the beomaster (via the PC button) and audio comes out, but when I switch to N.Radio (either in the main room or a link room), the beocentre 2 displays the programme running, but no sound comes out. I suspect the problem I have is having two audio masters, so I’ve switched the beomaster to “audio master off” but I still get the issue. I’d appreciate any advice on what settings each should be.
any advices?
regards
frog
Camberley UK
Posts 624
frog replied on Fri, Apr 6 2018 12:30 AM
Actually, I think I have a bigger problem, the sound should be coming  through the ML I would think, but it isn’t - though the data is as the titles show up on the beocentre 2. The speakers switch on, but no sound...
i’m Perplexed!
frog
Camberley UK
Posts 624
frog replied on Fri, Apr 6 2018 1:49 PM
Actually, answering my own panic - powering off the beocentre 2 completely allows the beosound 5 to work perfectly. With the beosound 5 set as audiomaster option 1
Is is there an option setting that would allow me to use both, with the Beosystem 2 for DAB radio and CD and DVD, with the beosound 5 for N.Music and N.Radio?
frog
Camberley UK
Posts 624
frog replied on Fri, Apr 6 2018 5:16 PM
Speaking to myself here....
connected up the Beocentre 2 via SCART, so DVD works, but Radio and CD doesn’t. I really would like an option to have radio and CD co-existing with the beosound 5.
Page 1 of 1 (4 items) | RSS
