hi,
im struggling with setting the options for my system - the main room comprises of:
Beosystem 3 (Option setting 2)
Beocentre 2 (Option 0)
Beosystem 5/Beomaster 5 (no audiomaster)
the speakers are connected to the Beosystem 3.
what I’m finding is that I can control the beomaster (via the PC button) and audio comes out, but when I switch to N.Radio (either in the main room or a link room), the beocentre 2 displays the programme running, but no sound comes out. I suspect the problem I have is having two audio masters, so I’ve switched the beomaster to “audio master off” but I still get the issue. I’d appreciate any advice on what settings each should be.
any advices?
regards
Actually, I think I have a bigger problem, the sound should be coming through the ML I would think, but it isn’t - though the data is as the titles show up on the beocentre 2. The speakers switch on, but no sound...
i’m Perplexed!
Actually, answering my own panic - powering off the beocentre 2 completely allows the beosound 5 to work perfectly. With the beosound 5 set as audiomaster option 1
Is is there an option setting that would allow me to use both, with the Beosystem 2 for DAB radio and CD and DVD, with the beosound 5 for N.Music and N.Radio?
Speaking to myself here....
connected up the Beocentre 2 via SCART, so DVD works, but Radio and CD doesn’t. I really would like an option to have radio and CD co-existing with the beosound 5.
