how to connect turntable/ipod/iphone to beosystem 3??
Andreaf9690
Posts 6
Andreaf9690 Posted: Fri, May 25 2018 11:22 AM
Hello everyone.
I own a B & o  5.1 surround system with beosystem 3.
I want to connect my turntable to the BS3 (reloop 7000), I connected the RCA cables to the input of an amplifier (and so far the signal works), and then connected to the BS3 output in the Av6 socket (RCA inputs). I have configured the socket as CAMERA, however when I call the CAMERA source from my Beo4 remote control, no sound comes out. What am I doing wrong?
same results if i try to connect my iphone with the minijack
thanks everyone
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome to Beoworld
Did you go through the configuration steps for the AV6 input in the menu?
Andreaf9690
Posts 6
I suppose so...
Andreaf9690
Posts 6
I made some attempts and i noticed that the audio source (spdif/rca) works only if there's also an hdmi connection active in the same source.
The strange things is that another BS3 that i have in my parent's house works flawlessy without this workaround.
is it related maybe  because i have connected a non B&O screen to my setup? Confused
TWG
Posts 1,672
TWG replied on Fri, Jun 1 2018 9:36 AM
Is your parent's Beosystem 3 connected via Masterlink to other devices or stand alone? Are both (yours and your parent's) BS3 the same variant (MK1, MK2 or MK3)?
Andreaf9690
Posts 6
The beosystem 3 are both MK1.
Both have 5.1 b&o surround system, in my case Beosound9000 via masterlink, in my parents, Beocenter2.
They have beovision 4-50,  in my case LG monitor...
Page 1 of 1 (6 items) | RSS
