Bought a Beocenter 9300 with defektive CD drive - I thought...But, there was other problems too - the remote control did not work.Not the Audio 0 problem - but a defektive IR module.After looking into other posts regarding IR problems, I figured what was the problem.Change the capasitor C9 - 22uF, and it works again.Hope this can be a help to others with the same problem.PS.: There is another post regarding IR problems on LC2.
https://archivedforum2.beoworld.org/forums/t/11884.aspx
Its the same problem :)
this is a typical problem with the SMD capacitor used with the IC.
I had the same problem with the IR receiver in a BeoLab 3500, which after exchanging the capacitor was able to react on IR remote.
Ralph-Marcus
