Beocenter 9300 - remote control problem
Jan_Jacobsen
Posts 10
Jan_Jacobsen Posted: Thu, Jun 28 2018 12:08 AM
Bought a Beocenter 9300 with defektive CD drive - I thought...
But, there was other problems too - the remote control did not work.
Not the Audio 0 problem - but a defektive IR module.
After looking into other posts regarding IR problems, I figured what was the problem.
Change the capasitor C9 - 22uF, and it works again.
Hope this can be a help to others with the same problem.
PS.: There is another post regarding IR problems on LC2.
https://archivedforum2.beoworld.org/forums/t/11884.aspx
Its the same problem :)
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Jun 28 2018 11:41 AM
this is a typical problem with the SMD capacitor used with the IC.
I had the same problem with the IR receiver in a BeoLab 3500, which after exchanging the capacitor  was able to react on IR remote.
Ralph-Marcus
Page 1 of 1 (2 items) | RSS
