I've recently purchased on eBay in USA MMC 4 not working / spares or repair, which pretty much everyone said not to....with the thought on my mind I've purchased MMC5 from S.Hammer and send it to re-tipp to Mr Schuerholz
Than I've got message from Axel that the MMC4 could be repaired indeed and he's on it followed shortly with other message (today) that the MMC5 arrived and will be re-tipped soon.
Which one to keep is the question (I'm just a poor boy..... , cannot afford keep both really ) ?
bob
P.S. It turned out that once again that either you haven't got nothing or surplus once more.... and to make it even more interesting there are now few complete BC2200 (with stylus etc) emerging for sale for fragment of the price.....
Don't worry - be Happy
Keep them, you will find that the MMcs you buy or receive with a BG, are bad or will go bad shortly, so if you have plans of buying more BGs, keep your MMCs
There are no technical/electrical differences between the MMC4 and MMC5 if retipped to the same option - your new MMC5 will perform just as well and fit the same systems as a retipped MMC4.
The only difference will be that there is another number on top of the cartridge. Keep the MMC4 if you need one for a future Beogram
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
BTW, I have a SP14 by Axel for repair, and I ordered a belt for my BG 1202, he will ship these on Oct. 8.
Gratz,
that be another one done....
SP14 I have in my BC3500 - good stylus
Søren Mexico: BTW, I have a SP14 by Axel for repair, and I ordered a belt for my BG 1202, he will ship these on Oct. 8.
That was my thoughts as well, thanks for advice Soren (I couldn't find any differences, but strangely MMC4 seem be suited/recommended to many more Boegrams unlike the MMC5)
I have coming in BG 1202 as part of payment / exchange of BC3500 repair - sadly they both with SP14's
Shall economical situation allow, I probably will keep both, fit the MMC5 into my BC2200 and hold on to MMC4 (unless someone come up with offer I be mad to refuse)
Søren Hammer: There are no technical/electrical differences between the MMC4 and MMC5 if retipped to the same option - your new MMC5 will perform just as well and fit the same systems as a retipped MMC4. The only difference will be that there is another number on top of the cartridge. Keep the MMC4 if you need one for a future Beogram
There is not much difference - the diamond on the original MMC4 is slightly better and has a slightly tapered cantilever. It would not surprise me if Axel has made your MMC5 into a MMC4!
Peter
Hi Pete,
yes that's exactly what he's doing ;) (you been around to long .... )
In ideal world I be able to keep both (something to put it in is more likely to happen than to get Beogram with good stylus, at least at my budget, that is)
Peter: There is not much difference - the diamond on the original MMC4 is slightly better and has a slightly tapered cantilever. It would not surprise me if Axel has made your MMC5 into a MMC4!
