Hello,
I have a BEOVISION 7 with a pin code, we dont remember the original pin, but B&O gave the mastercode
In the manual IT says tot gold the rewind button for at least 3 seconds and then you should be able to put in the mastercode.
The button is working. Anyone have An idea what tot do?
2 days without tv now and is Sunday's do Can't contact B&O
Thanks in advance
PS i use a beolink 1000 remote. All the buttons are working because when i enter the pin the rewind button does respond
This link shows 2 different Beolink 1000 and different buttons for < and << so might assist you.
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.21.35.Folder1/beolink1000a.jpg
Stoobie
I have the Beolink 1000 MK3 remote. What should i do now?
IT drives me crazy hahaha
There are 4 buttons with arrows grouped in the middle . Have you tried holding the "down" ▼ instead of << button?
Not at home right now Will try it in 3 hours when i AM at home thanks for helping
No luck with this either
Have you had the TV working before with the Beolink 1000? This remote was not made to use with your TV so that is what may be causing the problem.
Yes IT was working. And the rewind button Give response too when i enter a pin and then press rewind is goes back one digit
Been to bang and Olufsen centre and i bought a BEO4 remote... Stil no maatercode menu unbelieveable
The new remote properly needs to be the version with the navigation key...
Otherwise you are properly forever stuck!
I have this one.
http://www.staegerag.ch/cms/store-4/beo4-type-1710-navigation/
Tommorow b en o mechanic Will come tot my house
daveijmuiden1: Tommorow b en o mechanic Will come tot my house
That was going to be my next suggestion
dave?
I have exacktly the same problem, did you evere find a solution?
kindly regards, sitting in southern Germany without TV
Jørgen Jørgensen
Untere Mangfallstrasse 9
83059 Kolbermoor
