Mastercode menu dont come up
This post has 14 Replies | 4 Followers
daveijmuiden1
Posts 9
daveijmuiden1 Posted: Sun, Mar 11 2018 8:08 AM
Hello,
I have a BEOVISION 7 with a pin code, we dont remember the original pin, but B&O gave the mastercode
In the manual IT says tot gold the rewind button for at least 3 seconds and then you should be able to put in the mastercode.
The button is working. Anyone have An idea what tot do?
2 days without tv now and is Sunday's do Can't contact B&O
Thanks in advance
daveijmuiden1
Posts 9
PS i use a beolink 1000 remote. All the buttons are working because when i enter the pin the rewind button does respond
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo replied on Sun, Mar 11 2018 11:25 AM
This link shows 2 different Beolink 1000 and different buttons for < and << so might assist you.
https://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.21.35.Folder1/beolink1000a.jpg
Stoobie
daveijmuiden1
Posts 9
I have the Beolink 1000 MK3 remote. What should i do now?
IT drives me crazy hahaha
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo replied on Sun, Mar 11 2018 12:00 PM
There are 4 buttons with arrows grouped in the middle . Have you tried holding the "down"    instead of << button?
daveijmuiden1
Posts 9
Not at home right now Will try it in 3 hours when i AM at home thanks for helping
daveijmuiden1
Posts 9
No luck with this either Super Angry
Stoobietoo
Exeter, Devon, UK
Posts 692
Have you had the TV working before with the Beolink 1000? This remote was not made to use with your TV so that is what may be causing the problem.
daveijmuiden1
Posts 9
Yes IT was working. And the rewind button Give response too when i enter a pin and then press rewind is goes back one digit
daveijmuiden1
Posts 9
Been to bang and Olufsen centre and i bought a BEO4 remote... Stil no maatercode menu unbelieveable
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, Mar 14 2018 11:02 AM
The new remote properly needs to be the version with the navigation key... Smile
Otherwise you are properly forever stuck!
daveijmuiden1
Posts 9
I have this one.
http://www.staegerag.ch/cms/store-4/beo4-type-1710-navigation/
Tommorow b en o mechanic Will come tot my house
daveijmuiden1
Posts 9
I have this one.
Stoobietoo
Exeter, Devon, UK
Posts 692
daveijmuiden1:
That was going to be my next suggestion Big Smile
Stoobie
jojoe
Posts 13
jojoe replied on Mon, Aug 6 2018 2:26 PM
dave?
I have exacktly the same problem, did you evere find a solution?
kindly regards, sitting in southern Germany without TV
Jørgen Jørgensen
Untere Mangfallstrasse 9
83059 Kolbermoor
Page 1 of 1 (15 items) | RSS
