Hello everyone,
I have a BS9000 MKIII connected to BV8-40 via ML. Penta active speakers and BL2 are connected directly in BV8-40. All work fine (TV-RADIO-CDs). Connected my BG4500 to the AUX port in BS9000 press A AUX (which appears on BS9000 "screen") the BG plays a record but I do not hear sound from the speakers. What am I doing wrong?
Thank you all in advance for your help.
Spiros
Hi Spiros,
Are you certain that the Beogram is working correctly please? If you plug headphones into the Beosound and play a record, can you hear the sound?
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve,
