BS9000 connect a BG4500 to AUX port
This post has 2 Replies | 2 Followers
papas_spiros
Posts 24
papas_spiros Posted: Sat, Aug 25 2018 1:31 PM
Hello everyone,
I have a BS9000 MKIII connected to BV8-40 via ML. Penta active speakers and BL2 are connected directly in BV8-40. All work fine (TV-RADIO-CDs). Connected my BG4500 to the AUX port in BS9000 press A AUX (which appears on BS9000 "screen") the BG plays a record but I do not hear sound from the speakers. What am I doing wrong?
Thank you all in advance for your help.
Spiros
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Spiros,
Are you certain that the Beogram is working correctly please?  If you plug headphones into the Beosound and play a record, can you hear the sound?
Kind regards, Steve.
Steve.
www.soundsheavenly.com
papas_spiros
Posts 24
Hi Steve,
I can now hear sound from my Beogram 4500 connected to A AUX powerlink port of the Beosound 9000.
Actually following your advice I checked the Powerlink cable and I had to move it (pressed it) until was connected properly.
Thank you so much for your reply
Spiros.
Page 1 of 1 (3 items) | RSS
