Hi all:
If there is something/somewhere I can go to read about this properly, please let me know, if not could you please answer these questions for me:
I don't really understand what Masterlink does - is it like Sky Multiroom before Sky Multiroom and if so does it push the image from the main TV or source to other sources that you want it to run to?
I am looking at getting a Beovision 6 and this will be my bedroom TV. I have a non-HD Beovision 5 which is my main TV but as the 6 has DVD/radio capabilities, for the purposes of the system this might become the master.
Is there really a practical application for Masterlink these days or is it redundant?
Can it only be achieved via cables i.e Masterlink cables?
Graham
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
BeoNut since '75
Here is the BeoWorld descriptions with links
https://www.beoworld.org/faq_view.asp?id=92
Hi Graham,
There is a full Masterlink Handbook available in the downloads section of Beoworld (for Silver and Gold members) which gives a clear and detailed explanation of the full workings of the system. I would recommend upgrading your membership to take advantage of this information and the many other documents available to Silver and Gold members.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve:
Thanks, will do later and that is most helpful.
