I think you have to change the option setting of your Beosytem using your remote. I'm sure someone else can tell you how to do that!
Brengen & Ophalen
There is actually a functionality to turn off the remote function, I noticed that by mistake when I added my Beosound 2300 without any speakers in the Beo5 config. So it is not necessarily a malfunction.
At the moment, I do not remeber how I did it though but I bet I found the answer on this site.
(one thing you could try if you have a Beo5 + config tool is to add it to a zone with speakers - might work)
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
On the Beolink 1000, SOUND 1 STORE.
Might work!
Peter
THIS WORKED FOR ME!!!!
on a beosystem 6500, with the beolink 1000
THANK YOU SO MUCH
