BeoLink Active question
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen Posted: Mon, Nov 16 2015 10:18 AM
Does anyone know how to reset a BL Active to neutral values for bass, treble, right/left?
In the 'old days' having a BeoLab with display made it easy to read out the values (and choose, what you prefered). But that is not possible with current BL's.
Sure you could rely on your hearing abilities/preferences, but having a neutral starting point would be better imo.
Any ideas?
Raeuber
Germany
Posts 2,542
Raeuber replied on Mon, Nov 16 2015 12:22 PM
Good question, MM. But I think this is not possible. After you have stored your preferred settings (with S.STORE) these values can't be reset anymore. There is no 'factory reset', as far as I know. That's why I only stored my preferred VOLUME with S.STORE, but not BASS, TREBLE and BALANCE, because the neutral settings are perfect for me.
Regards
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
If you - like me - use and have used different BL Actives in different configurations with different speakers,
you may have (had) to change the values some times.
Not to speak of those, who buy one second hand!
I would be very surpriced, if there is no such possibility!!!
P.S. I have to think of a way to dive into 'the reservoir of knowledge' (in Struer) ;-)
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Nov 16 2015 1:35 PM
There is a RESET command that can be added to LIST but I think this just resets the levels to the stored value and not to 'flat' so it probably won't help.
The only way I can think to do this would be to determine the number of steps for each control - either from memory if you can remember from when you had speakers with a display, or by trying to count the audible changes from minimum to maximum. Then adjust all the way in one direction, followed by half the number of steps back.
Not an ideal solution I know, but I'm not aware of any other way to do this.
Kind regards
Martin.
Millemissen
Flensborg, Denmark
Posts 14,680
1: that is just a reset of the temporary values, yes.
2: that - of course - is, what I have done so far.
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Oct 1 2018 11:51 PM
This thread seems to imply that one can set the left/right balance on an Active box.  However, when I step through A.SETUP on my beo4, I only get Bass, Treble, Loudness and S.Store.  No left/right.  Is it possible?
Thanks in advance,
Stan
Page 1 of 1 (6 items) | RSS
