No it isn’t. Just set it on 30.
Jacques
Automatic is not a setting. Thats just a label.
turn the knob clockwise to 30cm and Press lift.
martin
Dillen:Automatic is not a setting. Thats just a label. turn the knob clockwise to 30cm and Press lift. martin
Is the tonearm parallel to deck side when in rest position
It may be parallel to the deck, but not to the decks right side, adjust it according to the manual
Haventgotaclue:There is also a scrapping noise when the TT is going around?? Sorry for all the questions just new to fixing up TTs and what to get it spot on
Get the manual, available for silver and gold members, and do all the adjustments, and if not changed get a new belt from Dillen on this forum
Platter highs or center bad adjusted, transport screws, something below the platter in bad position, too tight new and not original belt. If the deck wasnt serviced before, it is time to do it, open the deck (manual) clean and lubricate all mechanical parts, clean and adjust all contacts,and then do all adjustment according to manual
Here a thread with some pics (some missing)
