Beogram 1202 tonearm cueing
This post has 14 Replies | 1 Follower
Haventgotaclue
Posts 20
Haventgotaclue Posted: Sat, Oct 6 2018 3:20 PM
Hi all
Just a quick question, my beogram 1202 when set to automatic cue is beginning the record half way through, is this just a unbalanced tone arm issue??
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 3:56 PM
No it isn’t. Just set it on 30.
Jacques
Haventgotaclue
Posts 20
Hi again Jacques! Wink
The TT is set to 30 but keeps starting play in the middle of the record?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 6 2018 5:25 PM
Then something is off. Was the tonearm forced at some point?
What does it do on 25 and 17?
Jacques
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Oct 6 2018 5:50 PM
Automatic is not a setting. Thats just a label.
turn the knob clockwise to 30cm and Press lift.
martin
Haventgotaclue
Posts 20
It’s possible that the tone arm was forced in the past as I haven’t long had the TT, will see what it does at 25 and 17 and get back to you probably won’t be till tomorrowWink
Haventgotaclue
Posts 20
Dillen:
martin
Hi dillen
That is what I done but still the tone arm lands half way through the record to play Indifferent
Søren Mexico
Mexico City
Posts 6,411
Is the tonearm parallel to deck side when in rest position
Haventgotaclue
Posts 20
Hi looked at the TT again today and took photos to help, so photos from top are starting playing position from 17,25,30
Haventgotaclue
Posts 20
Yep the tone arm is parallel to the Deck
Haventgotaclue
Posts 20
There is also a scrapping noise when the TT is going around?? Sorry for all the questions just new to fixing up TTs and what to get it spot onBig Smile
Søren Mexico
Mexico City
Posts 6,411
It may be parallel to the deck, but not to the decks right side, adjust it according to the manual
Søren Mexico
Mexico City
Posts 6,411
Haventgotaclue:
Get the manual, available for silver and gold members, and do all the adjustments, and if not changed get a new belt from Dillen on this forum
Haventgotaclue
Posts 20
Will give it a go thanks Smile any ideas on the scraping noise when the TT rotating?
Søren Mexico
Mexico City
Posts 6,411
Platter highs or center bad adjusted, transport screws, something below the platter in bad position, too tight new and not original belt. If the deck wasnt serviced before, it is time to do it, open the deck (manual) clean and lubricate all mechanical parts, clean and adjust all contacts,and then do all adjustment according to manual
Here a thread with some pics (some missing)
Page 1 of 1 (15 items) | RSS
