Hi
I have a problem that you may be able to solve.
I got a gift from my friend , a beosound 5 Encore where power supply is missing.What are the options?Can I DIY?Does anyone of you maybe have to sell one?
New ones are no longer available...only PCB as apare part.
Thanks for all your help :)
The PCB is the only part inside the power supply. So you can basically have a power supply if you can find something safe to mount the PCB in and then purchase the power cables for the input of the BS5 and for the other side of the PCB.
@Aussie Micheal - The reason why you had to put together the power supply is for the different mounting options, which were most likely through the wall.
Ah, you know... A little B&O here, a little there
Hi marexy,
I apologise but I don't know of any way to source these items, they are not something that I could produce.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
@Steve
This should so it, I suppose.
https://archivedforum2.beoworld.org/forums/p/11443/100178.aspx
Thanks MM,
Unfortunately I have not been able to get any progress with this so this won't be something that I could offer.
Thaks guys..
it seems that i have different problem..
I open the box ..and ..it's Beoosound 5 ...not beosoud 5encore :(
So i need Beomaster5 :(
There is no DIY there 🤣
