Screws under Beovision 8 26/32?
This post has 10 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Wed, Oct 31 2018 11:14 AM
I am always missing out screws to my Beovision 8 26/32 - I mean them under the tv to the aluminums foot or the wall bracket. They are very small. I have asked in several building hardware store without any luck.
Do you know the dimonsions of the screws? I will post a picture in the next post.
Master123456789
Posts 237
This one :)
madskp
Denmark
Posts 321
madskp replied on Wed, Oct 31 2018 11:45 AM
I think the thread is a standard M4 or M5 screw. I used another pair of screws for an alternative mount when I had a BV8 without problems. It might be difficult to find a screw with the same head as the original though
RaMaBo
near Munich
Posts 626
RaMaBo replied on Wed, Oct 31 2018 2:47 PM
those screws are M4 x 12L
The head of the screw is up to you Smile
Ralph-Marcus
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker replied on Wed, Oct 31 2018 2:48 PM
I think they are M4, just make sure you ask for "counter-sunk".
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Rob - Danish AV
Melbourne
Posts 376
Confirm they are m4, can be 15-25mm long
Master123456789
Posts 237
Thank you very much - I knew you good guys in here could help. :)
Master123456789
Posts 237
so I can buy them from size 15 mm to 25 mm? The best must be 25 mm then?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Nov 1 2018 9:36 AM
Go for 20mm to be in the middle. Plenty available cheaply online :)
Link to Bolts HERE
Master123456789
Posts 237
Thanks for the link - I have ordered now ;-)
Master123456789
Posts 237
Everything is fine! :)
Page 1 of 1 (11 items) | RSS
