I am always missing out screws to my Beovision 8 26/32 - I mean them under the tv to the aluminums foot or the wall bracket. They are very small. I have asked in several building hardware store without any luck.
Do you know the dimonsions of the screws? I will post a picture in the next post.
This one :)
those screws are M4 x 12L
The head of the screw is up to you
Ralph-Marcus
I think they are M4, just make sure you ask for "counter-sunk".
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Confirm they are m4, can be 15-25mm long
Thank you very much - I knew you good guys in here could help. :)
so I can buy them from size 15 mm to 25 mm? The best must be 25 mm then?
Go for 20mm to be in the middle. Plenty available cheaply online :)
Link to Bolts HERE
Thanks for the link - I have ordered now ;-)
Everything is fine! :)
