Hi all,
I have a BV10-32 with an easel stand and I want to replace the stand with the motorised table stand. I found one secondlife but I have to remove the easel stand first. I have no idea what I'm doing wrong but it doesn't move an inch. It has no (visible) nuts and bolts so I gather I have to push is downwards and up. Unffortunatly it won't work ;-( Anyone a clue as for what I'm doing wrong?
Regards, Bart
Mine had a stand attached but you had to lay it on it's back and then undeneath the metal bar of the stand at the edges you should see some screw holes - there are two each side and you need a heaxagonal type screwdriver to remove them - yours maybe covered by they should run through the bottom of the stand and up into the TV. They are a real pain and be careful as I messed mine up using the wrong screwdriver - someone maybe able to be more specific about the screws than me.
Thanks a million Andrew! I found the screw holes, at least they look like it. There is a little spring underneath them which release the stand. Identical for all stands, not just the easel stand.
https://archivedforum2.beoworld.org/forums/p/27897/220342.aspx
