BeoVision 10 Easel Stand Instructions
This post has 9 Replies | 1 Follower
futurist
Posts 29
futurist Posted: Thu, Sep 28 2017 11:56 AM
Some months ago I purchased a second hand easel stand, but only now getting around to using it (my BV10 has been on the wall, but moving house and fancied a change).
However - I cannot find installation instructions anywhere.
I'm sure it's not hard to install, but I want to know what Im doing before I take such a heavy TV off the wall.
Would anyone have fitting instructions they could post?
Thank you
Sal
California, USA
Posts 1,197
Sal replied on Thu, Sep 28 2017 3:48 PM
I have the instructions for the BV11 Easel Stand, I can send when I get home. However, obviously, I'm not sure if they are exactly the same for the BV10, one would think that they wouldn't be all that different, though. Will post a link or send via PM when I get home later today.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Sep 28 2017 7:10 PM
What do you need to know, exactly?  Happy to talk you through it.
Lee
Smile
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
See Diagram Below
Regards Keith....
Sal
California, USA
Posts 1,197
Sal replied on Thu, Sep 28 2017 7:41 PM
Thanks Keith, looks like the same diagram on the easel stand for the BV11.
Millemissen
Flensborg, Denmark
Posts 14,680
Easiest B&O stand installation ever ;-)
futurist
Posts 29
futurist replied on Fri, Sep 29 2017 4:14 AM
Thanks Keith (and others for their responses).
Just to confirm, this is for the BV10 not the BV11?
Sal
California, USA
Posts 1,197
Sal replied on Fri, Sep 29 2017 5:35 AM
futurist:
I just confirmed, the BV11 instructions are similar, but what Keith posted is definitely not for BV11, as they don't perfectly match the BV11 instruction I just looked at. Good luck, please post pictures of your installation when completed.
Keith Saunders
Posts 5,495
futurist:
To be clear, what I showed and what was requested namely a Type 4722 Easel Stand for a BeoVision 10
The BeoVision 11 two Easel stands are slightly different:-
  • For BV11-40 and BV11-46 it uses a Type 4751
  • For a BV11-55 it uses a Type 4750
Regards Keith....
Aussie Michael
Melbourne, AU
Posts 3,730
Bringing up an old thread
Does anyone know perhaps how long the screw A's are and what type they are?
Thanking you
Page 1 of 1 (10 items) | RSS
