Hi all,
been doing some search and could not find a straight easy answer to this: how can I connect my BV7 mk2 with DVI to an Apple TV (with HDMI) and still get sound? Can I control the Apple TV with the Beo4?
Tks
Miguel
Hi Miguel,
You attach a standard audio cable (red/black) from the back of the ATV to one of the audio inputs in the TV and select which one in the main menu.
If you get stuck I can send you a picture.
Dan
danezro: Hi Miguel, You attach a standard audio cable (red/black) from the back of the ATV to one of the audio inputs in the TV and select which one in the main menu. If you get stuck I can send you a picture. Dan
I would like also to see that picture Danezro! And if possible to be more analytic on how the connections are done, because i want to connect also my MKII to ATV2
Dimitris-
Very likely the BV7 MKII will need SW Updates*) and, furthermore, you'll need an optical <> electrical (=Toslink <> RCA/Cinch) digital "translator" for an ATV-2 (newer black version).
*) 3 chips + Service Tool
ATV-can be controlled via Beo 4/5/6 if the "Apple Remote" has been added to your PUC-list
More details ? have a look at this thread: http://archivedforum2.beoworld.org/forums/t/330.aspx
