Beolab 2000 does not turn on
This post has 2 Replies | 2 Followers
1beofan1
Posts 1
1beofan1 Posted: Sat, Feb 23 2013 8:46 AM
Hope someone can help with and answer. Took Beolab 2000 out of storage after about 7 years. Bought beo converter box for masterlink connection, speaker stays in standbay mode but does not turn on either with remote or play button. Busted or ?????
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Feb 23 2013 10:27 AM
Can you give more details as to what you are conneting the BeoLab2000 to?
Is it the same equipment you used before it went into storage?
Did you power off the system BEFORE connecting the masterlink cable to the BeoLab2000?
Opman
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Sun, Feb 24 2013 6:50 AM
This Sounds like a masterlink Problem. Mine did the same when I connected it to a new ML with a wiring problem.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Page 1 of 1 (3 items) | RSS
