Recommendations on shops to rebuild BeoGram 5500 turntables?
Couldbfishin
Houston, TX USA
Posts 16
Couldbfishin Posted: Sat, Jan 5 2019 2:16 AM
I have two BeoGram 5500 turntables. One is working and I use it daily. However it has never been cleaned and serviced as far as I know. The other 5500 has some issues and also needs some service.
I am considering sending both to Pyramid Audio in Austin, TX. It is only a couple of hours drive from my home in Houston, TX. I  have used them to repair my Denon DP-45F and they did a good job on it.
There is a shop in Connecticut that has a good reputation for repairing Nakamichi gear, and I plan to send my RX-202 cassette deck to them soon. I see on their website they also repair B&O equipment, but I was hoping to get good work done for less.  I think it is $750 for a B&O turntable and $1500 for any other B&O equipment. The prices are on their website.
I see on the SoundSmith website they repair B&O gear.
I would like to hear recommendations on shops to use for good work at reasonable prices. I don't think we should say anything negative about these or any other service companies, but if you have one to recommend, I would appreciate hearing that.
DMacri
United States
Posts 881
DMacri replied on Sat, Jan 12 2019 12:18 PM
I have had success with Atlantic Systems here in Mass. Good quality service.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Tue, Jan 22 2019 1:08 AM
Amina Audio (Benny Amina) has repaired many of my B&O pieces. Benny is in suburban Atlanta.
There are several technicians on the Tapeheads web site that could repair your RX202. Personally, I would see if “Perry” were taking on new work now that his move is complete. I have purchased 2 decks from him (Yamaha K1020, Aiwa F800) and they are fantastic. It’s worth having a look around the Tapeheads site. You may find you just need to replace belts and/or an idler tire. I took a non working Nakamichi BX300 and brought it back to life with a $5 idler tire, a couple hours, and a some instruction from Tapeheads.
Page 1 of 1 (3 items) | RSS
