I have two BeoGram 5500 turntables. One is working and I use it daily. However it has never been cleaned and serviced as far as I know. The other 5500 has some issues and also needs some service.
I am considering sending both to Pyramid Audio in Austin, TX. It is only a couple of hours drive from my home in Houston, TX. I have used them to repair my Denon DP-45F and they did a good job on it.
There is a shop in Connecticut that has a good reputation for repairing Nakamichi gear, and I plan to send my RX-202 cassette deck to them soon. I see on their website they also repair B&O equipment, but I was hoping to get good work done for less. I think it is $750 for a B&O turntable and $1500 for any other B&O equipment. The prices are on their website.
I see on the SoundSmith website they repair B&O gear.
I would like to hear recommendations on shops to use for good work at reasonable prices. I don't think we should say anything negative about these or any other service companies, but if you have one to recommend, I would appreciate hearing that.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
